820-3332 - ppbus_g3h low
menatwork
The Board is pretty clean.
All the rails is there, however, the PPBUS_G3H is around 12.13V To low and don't detects the battery.
Any hint?
JohnB8812
12.13 is too low regardless. SMC_RESET_L voltage? If 3.3, then likely bad ISL6259 or bad SMC. If low, figure out why.
"Post exact voltage and dioe mode to ground on SCL/SDA lines of battery bus."
You are loosing time...
