820-3332 pulsing
tech
neat and clean mb
all rails comes fan spins for seconds and repeats
PLT RESET also same
tried BIOS / Tried without Q7950 all same
tech
I removed U2690 after that all voltages stable fan spins ,
CPU_RESET_L -1.05 coming (there is no Buffered CPU reset). but no chime no display
CPU reset is disabled too fast in this case; doesn't comply with Intel specifications.
It goes high once VCCIO appears (R1126), before power on sequence is completed.
Did you try SMC bypass?
You can also try disabling GPU, for test at least.
Resolder U8900 first, just in case...
