820-3435 NO SSD
2click
THIS BOARD DOESNT SHOW THE SSD, SO FAR I HAVE:
PP3V3_S0SW_SSD_FLT = 3.3
SSD_RESET_CONN_L = 3.3
SSD_CLKREQ_CONN_L = 3.3
SSD_PCIE_SEL_L = 0V (WHEN SSD PRESENT) 3.3 WHEN SSD REMOVED
SSD_DEVSLP = 0V
SSD_PWR_EN = 3.3
PCIE_CLK100M_SSD_N = 0V
PCIE_CLK100M_SSD_P = 0V
TRIED A DIFFERENT SSD, SAME RESULT...
"SSD_CLKREQ_CONN_L = 3.3"
Not good.
SSD must pull down this line when inserted.
Check connector and trace.
Post U3740 voltages.
2click
SSD_CLKREQ_CONN_L is 0v, I was checking the value with the SSD unplugged....
U3740
1 = 3.4
2 = 1.2
3 = 3.4
4 = 3.4
5 = 0
6 = 3.2
7 = 0
8 = 0
2click
C3710-17 are fine
desoldered U3710/11 to see underneath, they look fine and traces where ok. put them back... still nothing... by pressing ALT I get to the boot option, but get no SSD there... I can boot from external drive but can´t see any internal hard drive...
I am using 2 samsung SSD drives, with any of those, when the board turns on, the samsung chip on the SSD gets burning hot...
on PIN 38 of J3700 I get a resistance to ground of 2.9 Ohms is that normal value?
found that L7630 diode mode value is ,026 checking that area... everything seems to be fine... I get PP1V05_S0 with no problems,
P1V05S0_PGOOD = 3.3v
