KC Micro Tronix
Since you are dealing with liquid damage there is probably some pad eaten under a component such as a resistor or a IC. This one will be a hard one due to the intermittent nature of the problem. I recommend removal of the board and crawling over it with a microscope and a probe checking to see if resistors and parts in the damaged areas are securely attached. Also chips that have water damage on them I would pull to inspect pads.
