820-3437-B bad DC-IN board??
pinotschio
[FONT=arial, helvetica, sans-serif]Hi, this is my first repair attempt on a 820-3437-B. The measurement on the G3H Fuse is 8.17V which is too low I guess. So I'm thinking that the DC-IN board might be bad. Weird thing is, that the LED on the charger gave green and orange light, as well as a fan spin some times when I reseated the flex-cable. So the connection seams very fragile there.. What else could it be?[/FONT]
You must get the correct voltage on PPNUS line (aprox 8.5V) even without LIO flex connected.
Only 5pins DC cable is sufficient to start the board.
pinotschio
[FONT=arial, helvetica, sans-serif]So I`m getting 12,8V on Pin 2 at D7005 where I should be getting 18,5V and on Pin 3 for PPBUS_G3H I'm getting 8,17V where I´suppose to get 8,6V...Bildschirmfoto 2018-09-24 um 10.44.16.png[/FONT]
pinotschio
Ok, so on U7100 on Pin 12: 3.36V | Pin 13: 3.36V | Pin 9: 3.36V | Pin 15: 07,06mV?? Regarding J9650 : Pin 5 +6 have shortage
"Pin 9: 3.36V"
Muy mal, SMC thinks about overcurrent through R7020.
So check R7021/22 and traces to U 7100 ;27/28 should give 020.
"Pin 5 +6 have shortage
Sorry ment Pin 5 + 4"
STOP to measure in diode mode a powered board...
pinotschio
I'm sorry if this gets annoying for you. I checked Pin 9 again(in Voltage Mode) and it gave me: 31mV. Ok I read out J6950 and here are the measurements: Voltage mode=VM | Resistance to Ground= RG (Diodemode without MagSafe plugged in) --> Pin 5: 3,36V (VM) / OL(RG) Pin 4: 3,36V (VM) | OL (RG) . Both Pins have very High Resistance to Ground when measured in resistance mode as well. Hope I did everything right this time. I'm a complete newby.
SCL/SDA should indicate something on diode mode.
Check these lines with red probe at ground in diode mode.
You must get less than 1% difference.
"I checked Pin 9 again(in Voltage Mode) and it gave me: 31mV"
So, when can we trust you?
Our help is based on your measurments...
pinotschio
Bildschirmfoto 2018-09-24 um 18.22.59.pngBildschirmfoto 2018-09-24 um 17.00.15.png As I said, I'm completely new to measuring and the whole scene in general, which may be the excuse for this irritating informations. Anyway I´ll try my best and unattached are my findings.
pinotschio
The Flexcable is off since you told me to. I measured 1,8mV on R16101 for PP3V3_SUS and for PP3V3_S5 I got 1,9mV on R8133
pinotschio
So I looked further over the board and found a ripped off pad with a may ripped off resitor (R5100). The board view and the actual parts are a bit confusing. If there is/was a resistor, any idea if this is cause of my issue and where can I jumper the pad to? Attached are some small pictures
