820-3437-b green light no power
Sr. Robot
Hello, i have an 820-3437 with green light on charger but no power.
All rails are present till PP3V3_S4. It doesnt show any sign of corrosion.
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L, at same time.
If present. check for pulse at PM_SLP_S4/3_L.
Be aware, this board should restart 2 times before booting, when charger is connected.
Sr. Robot
Coils pulsing:
L7320
L7310
L7630
L7430
L7520
L7130
Coils not pulsing:
L3095
L7701
Pin 7 of U1950 is pulsing but 3 is not (0v).
Check all SPI Bus Series Termination resistors and their traces.
Clean/remove J6100, if needed.
Try known good working BIOS.
Sr. Robot
R6115 was giving me 380 ohms where it should be 15. I replaced it for a 15 one.
There was a trace missing from R6128 to R6123 and i soldered a wire, it has continuity now.
I clenaed J6100 and it looks pretty, should i still replace it?
U6100 is recognized by the programmer. I reprogrammed the BIOS with one from another 820-3437.
Still not turning on.
I noticed wheni try to turn on SMC bypass the fan spins for a sec then stops, then again and again.
