820-3437-B running slow
vsa100
Hi!
I have this 820-3437-B logic board, the cpu is running @800Mhz and fan spinning high.
Checked the board and found C6990 burnt/oxydated
Replaced it but same problems, and AHT gives me that errors:
PFM006 (issue with SMC)
PPN001 (issue with the power management system)
NDC001 (issue with the camera)
What you suggest to do?
Thanks!
"NDC001 (issue with the camera)"
That means ALS (Ambient Light Sensor) issue.
So clean camera connector and check its solders/traces.
vsa100
already checked camera connector and it's nice and clean!
Tomorrow i'm gonna check camera cable
(a camera problem can be connected to smc/pw management problem in your opinion?)
ALS and Finstack Temp Sensor share the same bus through LIO connector.
You may have other issue with Power Management V/I sensor.
Check LIO connector and flex.
Also try other LIO board/flex.
