Hello all,
I have loved watching the youtube channel and have had a fun time tinkering my self on some macbooks.
To cut to the chase, I have an 820-3437 that came in because it was not charging the battery. After opening up the system, I found some nice sugary mess on the back side of the board in the C1047 area. I also found A LOT of happy little solder balls sneaking out of many caps for the PPBUS_S5_HS areas (pretty much every cap on the CPU side of the board except for C7130-31 and a few in that area.
After gently cleaning with a toothbrush (I mean gentle - I didn't want to become a statistic that Louis talks about so much) the board no longer powered on... Great.
So I got to the trouble shooting. Had no G3H. Ended up replacing all the bad looking caps due to the escaping solder balls - Still no solution, Changed charger in board - no change. Swapped back old board and FM - it worked again. So I cleaned the connectors of that flex cable some more and no more problems with the onewire. Now I was back to the original problem of the battery was saying it was 0% and only working on the wall power.
Did some trouble shooting, replaced a few components/voltage rectifiers that the caps could have damaged due to heat, checked the feedback resistors, change them cause I wanted to be sure. Finally swapped out u7100 - still same problem. I had dropped the new u7100 before installing it so said, ok, lets try again. Swapped with another new one and battery was reading that it was charging/full.
Ran ASD and found a bad sensor in the battery pack (-27degrees on one of them) Just installed a new battery now.
SO, where I am at is, after installing a new battery, plugging in the charger displays the orange charging light, but the computer says 100%, unplug the charger and the battery jumps to about 93% Is this a battery calibration problem? I don't think so personally.
Other thing to note/question.
PPDCIN_G3H is 15.10v on pin 1 of Q7180 (inrush limiter) and 14.57v on the output pin 4 (originally this was not getting its signal from U7100 to open)
Q7130 has the same 14.57v on pin 2 but only 8.18v on pin 7. Well below the 8.6 listed in the schematic.
I have a feeling this is the problem as only 8.18v is going out to charge the battery max? Or is the sense circuit doing its job and thats all the 7.3v battery needs to max charge?
If this is a battery calibration thing, I'm all ears! This is my first battery swap for a macbook and wont be my last.
Have a great day and sorry for the mess of a post.
