820-3437 No chime, no video
Ryanlen2
Liquid damaged. Customer previously took it to another shop so the board is pretty clean. Looks like bios may have been fucked with. Fan spins only with I/O board disconnected. PVCC_SO_CPU is 1.695V. USB mouse works from other USB port. Thanks have a good one.
* Sorry. I meant I/O board cable disconnected.
Does it do the 3 times on/off? Can you do a PRAM reset from external keyboard? Caps lock working if you hold down ALT to go into boot menu?
Ryanlen2
No... Only does on/off 2 times then fan goes high. Cannot PRAM nor Caps Lock using external KB. Thanks man.
Ryanlen2
OK. Bought BIOS chip from ebay to test. Also bought a programmer from Ali. When I confirm it is BIOS issue and programmer comes in can you help with new BIOS flash? Thanks.
Ryanlen2
Hey Duke. I have checked traces and replaced BIOS. Still nothing. I have 3v3 V on 1,2,3,7 and 8 of U6100. Thanks man.
As this is a pre-fucked board it can be anything. Check for knocked off components, crap under SMC, corroded traces/resistors. There is no magic to pre-fucked garbage.
