StraightToThePoint
820-3437, liquid damaged
Symptoms are very strange. Board will start up, and take around 400-600 mah, then restart (normal), then take another 400-600 mah, and then go to around 700-800 and stay there.
We do have VCORE, and all other rails are present. No chime, No video (Externally or EDP), No post. When plugging in a USB HDD, the board will have USB light, and USB power, however after around 7-15 seconds, the USB light on the HDD will turn off, however the HDD itself wont! There is no blinking activity at all, due to the light turning off, and the HDD doesn't do its clicking or sound for searching through the HDD, just spin sound.
Ive recently discovered that on J3501 (Wifi connector) there is corrosion around pins 17-14. These pins are the USB BT pins and AP pins? What are AP pins if I may ask?
Im going to remove the J3501 connector and see if any change will happen.
