Bouba148
Hi Team,
I've this board that is not charging , no sign of WD, and already swapped battery
With the battery connected and the board ON :
ppbus: 8.37V
activity on SCL and SDA lines
pin 4 of Q7155 is mesuring 0.969V then pulsing to 8.35V in cycle.....which doesn't allow the battery to charge.
Also when the mba is OFF the board is not pulling power: 0.008A and at Pin4 of Q7155 it clycling between 0V to 7V in loop and clycles also at pin 5 from 0V to 5V
Already replaced Q7155 and U5601: without succes
I'm suspecting U7000 or upstream, have to find the reason of that interruption on pin 4 of Q7155......
ppbus: 8.37V
