This a1425 Board chimes like a bird but works from external monitor using HDMI you could use the computer normal which is weird but the screen is not recognize not even back light doesn't work or no image when testing voltage for on U9701 two missing voltage BKLT_EN and BKL_FET_CNTL even when you put voltage to BKLT_EN am still missing BKL_FET_CNTL but before i go to far when you turn on the mother board just for about 5 seconds you get on the LCD cable DP_INT_AUX_N 1.3v /DP_INT_AUX_P 1.6v /PP5VR3V3_SW_LCD 5v/ LCD_HPD_CONN 3.3v /LCD_HPD 2.8v/ but i don't get PPVOUT_S0_LCDBKLT 0.v when I jump BKLT_EN i get only 12.v on PPVOUT_S0_LCDBKLT one strange thing is on C9028 /C9029 toward the CPU is short toward each other but still gives voltage when you just turn on the motherboard on a good board there is no short on those caps. Things i replace LCD connector /u9701 tried two different screens / replace resistors around u9701 check diode mode all good reading and even replace R7402/R7403 from u7400 and u7400 and over kill still all the same even did pram reset and smc lid is working any help is needed maybe i miss some thing or i may have left out something i did and forgot to write it on this post thanks.
