820-3462 not charging the battery
Sr. Robot
Hi, got a 820-3462 that is not taking charge from the battery or charging the battery correctly.
If the laptop is shutdown it charges the battery very slow, about 10% per several hours, and even if the battery is charged it will shutdown if charger is disconnected.
Tried known working battery, no change. The battery contacts are good and clean. Charger is OEM 87w
SDA/SCL lines are 0.470 on diode mode.
PPBUS_G3H without battery connected is 12.53v
It shows everything:
Full cap mah: 6669
Cycle count: 1
Condition Normal
Battery Installed: yes
Amperage: 934
Votalge: 10243
PPBUS_G3H_R and PPVIN_G3H_P3V42G3H are both 1.1v and going down with only battery connected.
R6905 is 10ohms and has continuity.
Q7055 voltages with battery and charger:
CHGR_BGATE= 2.5v
PPVBAT_G3H_CHGR_R = 10.2v
PPVBAT_G3H_CONN = 10.2v
PPBUS_G3H with battery connected is 10.2v (without battery is 12.5v)
"PPBUS_G3H_R and PPVIN_G3H_P3V42G3H are both 1.1v and going down with only battery connected"
Bad battery, broken trace, or battery doesn't get correct activation.
