1 0
2 16.8
3 4V
9 0
12 3.4
13 3.41
14 3.20 then drops to 3.16 and goes up to 3.20 in a loop not sure if its normal behavior
15 0
17 12.26
19 5.45
20 5.46
27. 16.56
SCL/SDA
Is it PIN 10 and 11 on U7000?
SMBUS_CHGR_SCL AND _SDA? If it's
Replaced the SMC with another one with the same schematic description from a board 820-00165
Now the machine is turning on.. I do have greenlight
HOWEVER its really SLUGGISH
and If I try to turn on only using the battery without the magsafe connected it goes to login and starts loading the system and the crashs and restar in an infinite loop
Already did RESET SMC, RESET PRAM
Fan is at full speed
Also important to mention that CUSTOMER HIMSELF replaced the battery but it charged good until 100%
