820-3476-A Won't Charge Battery/Run Off Charger
JohnB8812
Replace the ISL, Q7130, and Q7155 all at the same time. Also double check all traces under and around Q7130
jadao
You can also check scl/sda lines diode mode, they should be really close one each other, usually around 0,489-0,500.
Check resistor values R5380, R5381.
Check for any short on both lines.
Make sure U7100 is well soldered.
CRC2018
Thanks for your replies - can confirm after having replaced Q7180, U7100 and Q7130 again and also running a jumper wire for CHGR_PHASE from L7130 to C7125 the macbook is now charging and producing 12.3v PPBUS from the charger as normal.
thanks for your advice.
"producing 12.3v PPBUS from the charger as normal."
That is not normal!
Unless your multimeter doesn't read correct.
Battery is charging?
