820-3476 Board gets warm, no fan spinning, not booting up, Corrosion around U7501
SamMac
Hey another A1502 board for repair.
The board came in with not booting up and saw corrosion around U7501 with Pin 12 without a track which I made a jumper to pin 1 of R8140 and also replaced U7501. Unfortunately it hasn't made any changes and I also didn't take a complete list of the voltages I was getting before attempting the repair so I've only got the measurements after the repairs.
The CPU is getting warm and I've check all the traces and rails but don't see anything else wrong with the board. Hopefully someone can advise what I could check on next.
[TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
[TR]
[TD="width: 220"]PPBUS_G3H[/TD]
[TD="width: 147"]1.150V[/TD]
[/TR]
[TR]
[TD]PPDCIN_G3H[/TD]
[TD]16.92V[/TD]
[/TR]
[TR]
[TD]PP3V42_G3H[/TD]
[TD]3.39V[/TD]
[/TR]
[TR]
[TD]PPVRTC_G3J[/TD]
[TD]3.39V[/TD]
[/TR]
[TR]
[TD]PP5V_S5[/TD]
[TD]0V[/TD]
[/TR]
[TR]
[TD]PP5V_S4[/TD]
[TD]0V[/TD]
[/TR]
[TR]
[TD]PP5V_S0[/TD]
[TD]0V[/TD]
[/TR]
[TR]
[TD]PP3V3_S0[/TD]
[TD]0.565V[/TD]
[/TR]
[TR]
[TD]PP3V3_S3[/TD]
[TD]0V[/TD]
[/TR]
[TR]
[TD]PP3V3_S5[/TD]
[TD]1.686V[/TD]
[/TR]
[/TABLE]
This does not sound good! PPBUS is low and CPU is getting warm. I suspect PPBUS is shorted to some secondary rail. Probably RIP.
L7130 is on PPBUS_G3H line; check with other coils...
Any other big coil shows 50-60 ohms to ground?
Remove F7140 and see where the low value remains.
SamMac
okay somehow I find that L7520 is actually showing short with PPBUS_G3H aswell.
ANd no some coils are showing 80 Ohms and some are showing way above that L7520 is showing around 2-5 Ohms.
I'll double check the situation with the fuse tomorrow.
Appreciate any help, thanks.
SamMac
Pin 6/7/8 is showing short even with the IC taken off
EDIT: above mesaurements with regards to Q7520
SamMac
trying to check every component on the lines but removing the capacitors still showing the P5VS4 rail as short.
Any component in particular do you reckon i should check out?
SamMac
Checked if U7501 is shorting the rail, but that seems like its shorting it even with that chip removed.
Removing F7140 I can see that Pin 2 is showing the 60Ohms (low resistance value)
JohnB8812
That seems like a short on pin 2 of PPBUS...inject voltage to see what heats up. Start low at 1 volt in case it's the CPU.
So you have 60 ohms at PPBUS_G3H?
Any secondary power rail (big coils) with same value?
If only L7520, then remove U7501 and check again.
Do NOT power up the board without U7501...
SamMac
without U7501 attached PPBUS_G3H is still showing 60 Ohms
Every other coil is showing the same or similar resistances when put against PPBUS_G3H
With Q7520 also removed it doesn't show any significant changes and no coils showing the same resistances as PPBUS_G3H (which is showing 35Ohms)
