820-3476 no display on mini display port
VinceLx2
This board had few small spots of water damage, I repaired them, and now I have chime, orange light on charger, but no display on mini display port. Internal display is ok, blinking folder.
R5350 and R5351 are ok, 2 kohm, voltage on all their pins is 3.4V
PP3V3RHV_S4_TBTBPWR_F = 3.3V
PP3V3_S4_TBTAPWR = 3.3V
PP15V_TBT =0V
TBT_A_HV_EN =0V
S4_PWR_EN =3.3V
R2887=10 kohm
Any idea how to continue?
HDMI also not working?
Thunderbolt problems usually not worth to spend time only for external video.
Check TBT_A/B_HPD on U3220/320, depending which port used.
VinceLx2
So, for what I have checked also with another board, there is no blinking folder possible on HDMI.
For this board HDMI is working, within OS X
With display port connected on A:
TBT_A_HPD = 3.3V
DP_TBTPA_HPD =3.3V
VinceLx2
PP15V_TBT = 0V, with or without cable connected
In diode mode, I have 0.56V on C3315
PPVIN_SW_TBTBST = 0V
TBT_A_HV_EN = 0V, with or without cable connected
also,
TBT_B_HV_EN = 0V, with or without cable connected
Port A:
On C3286: PP3V3_S4_TBTAPWR =3.3V
On C3211: PP3V3RHV_S4_TBTAPWR =3.3V
Port B:
On C3386: PP3V3_S4_TBTBPWR =3.3V
On C3311: PP3V3RHV_S4_TBTBPWR=3.3V
I have these values with or without cable connected
VinceLx2
Here are the voltages on U2800:
PP1V05_TBTRDV = 1.01V
PP1V05_TBT = 1.01V
P1V05TBT_SW = 0.95V
PP1V05_TBTCIO = 1.00V
PP3V3_S4_TBT = 3.3V
PP3V3_S4_TBT_F = 3.3V
PP3V3_TBTLC = 3.3V
PP3V3_TBTRDV = 3.3V
TBT_EN_CIO_PWR_L = 0V
TBT_PWR_REQ_L = 0V
Seems ok. I have these values with or without cable connected
Check TBT_POC_RESET_L and TBT_PWR_ON_POC_RST_L.
You can try changing/reflashing U2890.
If still the same, change U2800.
VinceLx2
TBT_POC_RESET_L = 3.3V
TBT_PWR_ON_POC_RST_L = 3.3V
Can I try to replace with U2890 from a spare 820-3787 board, also with 2 display ports?
Do you have a dump for this chip?
I can flash with the same tool I use for SPI ROM/BIOS, correct?
VinceLx2
Ok.
Can I try to replace U2890 with the same chip from a spare 820-3787 board, also with 2 display ports?
VinceLx2
Ok, last question: can I try to replace U2890 with the same chip from a spare 820-3787 board, also with 2 display ports?
