820-3476 no ppbus
Check first resistance to ground at PPBUS_G3H; diode mode, red probe to ground.
Post exact value for R7180/81 and R7185/86, measured onboard.
Also need voltages for U7100; pins 2, 3, 9, 19, 20.
shanenin
I will verify those reading for you when I get back to the shop.
Am I correct in my reasoning that the gate, chgr_agate, needs to have a low voltage to turn on mosfet 7180 and that fact it is high is a problem? Helping me with these extra questions helps my general understanding and helps me learn.
shanenin
As you requested:
ppbus_g2h resistance to ground 610ohm .123 diode mode
r7180 99k
r7181 62k
r7185 470k
r7186 300k
isl6259
pin2 15.1v
pin3 4v
pin9 .04v
pin19 5.46v
pin20 5.46v
May I ask a question? Is chgr_agate with its high voltage stopping q7180 from turning on? From what I think I understand about mosfets, that seems to be an issue. Is my understanding of this correct?
If ACIN is OK, ISL6259 should open Q7180; if no short at R7120, of course.
But Q7180 could be bad.
Resistor readings do not point to Q7180 leakage, but change it just in case.
shanenin
Thank you 2informaticos for spending this extra time explaining stuff. I am asking the following question to understand, not argue. Before replacing q7180 don't we first need to get the enable fixed? On a working board both chgr_agate_div and chgr_sgate_div are about 6.5 volts. On this unworking board, they are 15.8v and 12v. The specs for the mosfet are about 2v for the gate threshold. Until we figure out the gate issue, should we even worry about the mosfet? Then my logic is since we changed u7100 already it may one of its inputs causing the issue. I will change q7180 just in case
"I am not getting any current passed through q7180"
I'm wondering how do you get 12V at CHGR_SGATE_DIV, if no voltage at R7120 available.
Unless Q7180 is bad, or U7100...
"we first need to get the enable fixed?"
U7100 controls Q7180.
shanenin
I think I follow you. Even if chgr_agate_div is not turning on, but with 12 volts at chgr_sgate you should get something coming out of the q7180.
shanenin
changed q7180, u7100, and r7185(just because). Still high voltage on chgr_agate_div.
edit added later//
let me double check all of the information I gave you. I think I may have made some mistakes
shanenin
I double checked everything and the numbers I gave you seem correct. I also switched r7186. From what I can tell it seems like u7100 is not pulling the voltage down on chgr_agate.
CHGR_AGATE should be pulled down first.
If not, NO voltage possible to arrive at R7120.
Second part of Q7180 is always ON, through internal diode; even if CHGR_SGATE is high.
Post other voltages for U7100, apart of above mentioned.
Pins 6, 9, 12, 13, 14, 15, 17/18, 25, 27/28.
If similar board available, compare diode mode readings on all pins of U7100 and other surrounding points...
