820-3476 no trackpad
Kyle93
Arrived with liquid damage. Replaced U4801 but still no trackpad or keyboard. Using known good keyboard and trackpad. Power button on keyboard works. Boots into OSX no problem.
Replaced U4801. diode mode on all pins of J4800 and J4813 is good. PP3V3_S4 is present. R4800 and R4808 are good as well.
what to check next?
KB/TP also not working before OSX?
Try to access boot menu for confirmation.
Did you try knwon good TP flex too?
Where was the liquid spill?
Post U4801 volatges before and after OSX login.
Kyle93
noticed pin 1 of J4800 3.4V without touchpad cable and with it its only 1.3V when it should be 1.56V
Bad J4800??
Aaaa, this is old style; always works in USB mode.
Don't bother to check voltages in OSX mode.
Pin 1/J4800 must be always 3.3V; w/ and w/o TP connected.
Looks like R4808 is bad in this case; replace it.
Kyle93
R4808 has been replaced. W/O TP connected 3.3V and without it its stuck at .793 V All traces look good.
What to try next?
Kyle93
Actually R4808 has been replaced several times on this board now. As soon as T/P is connected looks like it blows and has higher resistance.
T/P works fine on known working board
Kyle93
diode mode .388 pin 1 J4800 with and without trackpad and 3.3v with and without trackpad however as soon as screen is plugged in and OS starts to load drops to only .280V and R4808 blows.
jumper is ran from pin 1 of R4808 to pin1 of C3510 since PP3V3_S4 not present on R4808 otherwise.
Any ideas?
Kyle93
R4808 is no longer blowing up and no more shorts. Without t/p there is 3.3V on pin 1 of j4800 but once t/p is plugged in theres only 1.4V
A very small section of the board near C4808 is slightly popcorned. Could this have anything to do with the issue now? Anything else to try?
Kyle93
After cutting PP3V3_TPAD_CONN and soldering R4808 directly on pin 1 to J4800 then running wire to other terminal still have same symptoms. 3.3V without t/p and 1.4v with t/p
If you disconnect the other end of TP cable, still the same?
R4808 didn't blow up, even with 1.8V across it?
It is really 0 ohm?
