820-3476 PPBUS_G3H=0V
Remove U7100 and check diode mode to ground at pins 2, 19, 20.
If all good, solder new ISL6259A; may need to replace R/D7105 too.
VinceLx2
U7100, D7105 removed.
pin 2: 0V R=22.2 ohm
pin 19: 0.33V R= 65kohm
pin 20: 0.33V R= 65kohm
I removed R7105, pin 2: 3.1 V
But then on pin 1 of R7105/pin 3 of D7105 (CHGR_DCIN_D_R), I had again 0V, 2.2 ohm. The boardview shows a link to R7192, and finally it was C7190 shorted!
I replaced C7190, D7105. I soldered back the same ISL, now I see orange light on charger, but PPBUS_G3H=1.1V
Here are U7100 voltages:
1 = 16.5V
2 = 17.8V
3 = 4.3V
9 = 0V
12 = 3.4V
13 = 3.4V
14 = 3.4V
15 = 0V
17 = 1.1V
19 = 5.5V
20 = 5.5V
27 = 1.1V
Is ISL dead, or is there any other components to check?
VinceLx2
I removed F7140, same voltage on C7140
I replaced Q7180 from a donor board, same voltage
I replaced ISL6259A also from a donor board, and now I finally have 12.6V. Thanks for the help
I have a question about ISL9259: can ISL6259 AHRTZ be replaced with ISL6259 HRTZ, for example from 820-3115 boards? I cannot find datasheets for them
