820-3476 - USB port not working.
Alan.L
usb2.0 and usb3.0 not working.
tried flash drives mouse.
5v present on L4605.
5v present on usb port's power pin.
U4650
pin 10 - 3.4v
Diode mode on pin 5,6 of J4600
0.641
0.641
Diode mode on USB_EXTA_P and USB_EXTA_N
0.404
0.404
i've replaced U4650, its still the same.
USB port looks clean under microscope.
I/O board's usb port is working fine.
U4650 can be removed, bypassing D-Y data lines.
Check L4600 and C4620/21 integrity.
Compare diode mode readings on USB 3 data lines.
Alan.L
USB3_extra_r2d_p has contunity to c4621
USB3_extra_r2d_n has contunity to c4620
USB3_extra_r2d_c_p has 0.341 on diode reading (same on a known working good board)
USB3_extra_r2d_c_n has 0.341 on diode reading. (same on a known working good board)
USB3_exrta_d2r_p has 0.352 on diode reading (0.379 on a known working good board)
USB3_exrta_d2r_n has 0.349 on diode reading (0.378 on a known working good board)
L4600 and C4620/21 integrity look ok. i've even replaced them, just in case.
i've compared every lines with a known working good board. all measurements matched.
fuked pch?
solder joints look ok under the shield
Alan.L
no change, USB thumb drive doesn't light up. same as before.
5.1v is still present on pp5v_s3_ltusb_a_F after inserting a USB drive.
my usb desk lamp will power up ok.
