820-3478 iMac 27" Thunderbolt ports not working
CRC2018
Got an 820-3478 board in off an iMac 27" 2013 today but neither of the thunderbolt ports will work. If I connect a monitor to either of them monitor is showing connected no signal but there are no mirroring options coming up.
Is this likely to be burned U3210 and U3310?
Check if you get proper voltages on both Thunderbol vias, pages 30-32.
Is more likely a problem in a common area, than have both vias damaged.
CRC2018
Think you are correct as with further visual inspection U2800 looks discoloured like it has a burn mark on it. It's got like a brown spot on it.
Is there a source for replacement U2800 or it's a case of pulling one of a donor board only?
