820-3588 First LED blinks after power button press
No-Clean
Clean board, no shorts found on any of the rails from page 100.
All test are done with board alone and PS set up at 12.2V like I always test this boards, with iMac PS does the same thing.
Already replaced Q8450 and U7600.
I have steady PP5V_S5, PP3V3_S5, PP3V42_G3H
Not sure what else to check.
No-Clean
First LED is steady green, it blinks only when power button is pressed or if power on pads are shorted.
You've said steady 3V3_S5; seems not, probably didn't note drop pulse.
Should be good to use o-scope to monitor 12V_S5 also, at same time.
