820-3662 charred points on dcin board short on PPBUS_G3H
grmacs
Ok, so there was charred points on two inside points of charger input of DCIN board. I replaced DCIN, hooking mac charger up shuts the charger off. I have a short on PPBUS_G3H somewhere. Wasn't sure the best way to find the short without potentially blowing something important up like CPU or smc...
Looks to be happy case, you can inject voltage on PPBUS_G3H.
Start with 1V, maybe no need to reach 3V even.
Be sure to use a powerfull lab PSU; at least 10A limit.
Lift one side of the board and see where the short remains.
Inject voltage on that point.
If you discard 100% any shorted high-side MOSFET, you can inject higher voltage.
But with such low value, 3-5V should overheat something.
"I get a short from pin 1 to ground diode j8300 when display is plugged in but I really find it hard to believe its the screen"
I know people believing in god even without any reason; you have a powerfull one, at least...
Video cable, or display.
The short may also appear inside connector, only when the cable is inserted; change connector, if is the case.
grmacs
Man. you were right... I was able to test on another display and short is in the display. Customer is willing to pay for new display for this. Unbelievable. $$$
R7102 is not mounted; NO STUFF, as per schematic.
Exact PPBUS_G3H voltage w/ and w/o battery?
Did you try known good battery?
grmacs
So... apparently now it is not operating off of Magsafe only. not sure when that changed. I only have 1.5V slowly drops toward 0 on ppbus_g3h without battery plugged in. with battery ppbus_g3h is 11.1V
You must fix PPBUS_G3H problem first, on charger only.
PPDCIN_G3H and 3V42_G3H stable?
Do not expect fan spin with 1.7V at PPBUS_G3H.
Post basic voltages for ISL6259; pins 1, 2, 3, 9, 12, 13, 14, 15, 17, 19, 20, 27.
grmacs
1-3.6mv
2-2.7V
3-.477V
9-0V
12-3.42V
13-3.39V
14-3.26V
15-48mV
17-.9mV
19-5.53V
20-5.53V
27-16.2V
resistance pins
17/18 2.9ohm
27/28 22 ohm
