820-3662 doesn't charge the battery
BCN_Techs
Hi!
There was spill in the U7100 and U7501 area, so I replaced the two ICs and some components around them. Now the macbook can start and work (fans spin very fast), but it does not charge and puts "repair" in the battery state. The charger led blinks green twice, stays steady for 1 second and blinks twice again.
PS: I also tried two batteries and same result.
Tried known good battery?
Check voltage and diode mode to ground at SCL/SDA lines.
Post exact PPBUS_G3H voltage w/ and w/o battery connected?
Run corresponding EFI ASD test.
Check R7150/51/52 and traces; also check SMC_CHGR_BMON_ISENSE level.
BCN_Techs
SCL = 3.40V
SDA = 3.40V
PPBUS_G3H W= 10.80V
PPBUS_G3H W/O = 19.54V
EFI ASD = tomorrow (I'm downloading the files).
R7151 = 2.8 ohms
R7152 = 0.8 ohms
SMC_CHGR_BMON_ISENSE = 45k / 0V
"PPBUS_G3H W/O = 19.54V"
If this means PPBUS_G3H without battery (only charger), Q7130 is shorted; change it asap.
Be sure C7125 is good.
BCN_Techs
I have injected V = 1V into PPDCIN_G3H_CHGR and R7021 / 2 was getting hot: I changed the resistors, changed Q7130 but it still doesn't charge the battery (R7021 / 2 no longer gets hot).
With thermal camera, Q7130 heats up with charger and charger + battery.
BCN_Techs
I have changed it 3 times but it remains the same, it doesn't charge the battery and it gets hot (Q7130).
Did you check PPBUS_G3H each time?
Be sure Q7130 Gate pin has good contact with U7100.
Also check/replace C7125; its traces good?
BCN_Techs
Thanks to @2informaticos for the information: I have managed to get ppbus to be correct (12.58V) and to charge but, I still have problems: when turning on the macbook, the battery appears after 1-2 minutes of logging in (charger connected) and when I disconnect the charger, it keeps marking as if it was charging.
BCN_Techs
Yes, it recognizes it after 1-2 minutes of logging in.
With the new battery, I can turn on the macbook but still, it recognizes it after 1-2 minutes and even if I charge it, the percentage doesn't change (I look at the information about the remaining charge and after a few minutes, I check again).
Yes, I have tried with another original magsafe 2 and same behavior.
Remove internal SSD and try another USB macOS.
Or try with the SSD from another working machine.
Do PRAM reset 2-3 times.
Actual PPBUS_G3H, without battery?
