820-3747 liquid
Ryanlen2
Hi! I have a liquid damage Air that turns on occasionally.
The damage was minor and in these areas:
JTAG - Removed.
U1900 - Replaced and traces checked.
U7501- Replaced and traces checked.
U7701 - Cleaned
U3220 - Cleaned
U4430 - Replaced
Here are voltages
PPBUS - 8.5
PP3V42 - 3.42V
PPRTC - 3.3
PP5v_s5 - 5V
PP3.3v_S5 - 3.3
PP5V_s4 - 0
PP3V3_s4 - 0
PPVCC_S0_CPU - Fluctuates between .57V and .85V when fan spins.
All_SYS_PWRGD - 2.57V When fan spins.
Obviously missing PM_SLP_S4_L
Any direction will be greatly appreciated.
Have a good one!
"Obviously missing PM_SLP_S4_L"
Not true.
It pulses at least, if fan spins...
The fan needs 5V_S0.
"All_SYS_PWRGD - 2.57V When fan spins."
That means all the secondary coils pulse too; maybe not the CPU ones, check that.
Check U1950 area.
Pins 7 & 3 pulsing too?
Ryanlen2
Thank you for your reply,
L7630 fluctuates between .003V and .004V.
L3095 starts at .003V and stops at .040V
L7520 - 0V
L7430 - 0V
Pins 7 & 3 of U1950 are not pulsing.
Thank you!
Use o-scope for fast pulses, normal DC multimeter doesn't catch them.
Will be good to know if PM_SLP_S3_L pulses too.
Those mV you mentioned don't tell nothing; pick an o-scope...
Ryanlen2
Ok, thanks.
Update : This one may hang for a bit due to the fact that I don't have a scope.
Thanks for your input.
