820-3787-A does not turn on
Ares332
Hello friends, I have a macbook pro 820-3787-A that does not turn on.
PPDCIN_G3H_INRUSH = 0v
PPBUS_G3H = 0v
CHGR_SGATE = 0v
The voltage goes up to q7180 ppdcin_g3h = 20v and chgr_agate_div = 19.20v
I have changed the isl625 charging circuit 3 times thinking that the one they sent me was bad.
I have 6 months with that damaged macbook, it is mine, when I started to repair it, the macbook turned on when I pressed the charging ic.
Sorry for so much trouble, I hope you can help me fix it
Ares332
3V42_G3H YES = 3.4V
DIODE MODE
L7095 = 0.32v in 1 y 2 pin
F7140 = 0.440 in 1 y 2 pin
U7100
voltages
1 = 18.90v
2 = 20.22v
3 = 0v
9 = 0.061v
12 = 3.4v
13 = 3.3v
14 = 0v
15 = 0v
17 = 0v
19 = 5.4v
20 = 5.4v
27 = 0.403v
U7100
diode mode
1 = 0.653v
2 = 0.590v
3 = 0.547v
9 = 0.721v
12 = 0.322v
13 = 0.520v
14 = 0.545v
15 = 0.727v
17 = 0.435v
18 = 0.440v
19 = .325v
20 = 0.320v
27 = 0.652v
28 = 0.631v
Ares332
U7100
voltages
1 = 18.90v
2 = 20.22v
3 = 0v
9 = 0.061v
12 = 3.4v
13 = 3.3v
14 = 0v
15 = 0v
17 = 0v
19 = 5.4v
20 = 5.4v
27 = 0.403v
AL ENCENDER LA FUENTE SE QUEDA EN .008a
Ares332
PPBUS_G3H = 0.8v -- diodo 0.424 -- resistencia 1.007k
Isla6259 pin 24 = 0v -- diode 0..422v -- resistencia 1.130K
Ares332
U7100
Estos son los voltages, disculpa la demora
1 = 0v
2 = 20.15v
3 = 4.6v
9 = 4.3v
12 = 3.4v
13 = 3.3v
14 = 3.2v
15 = 0v
17 = 1.6v a 1.8v
18 = 1.6v
19 = 5.4v
20 = 5.4v
27 = 19.74
28 = 20.36v
Como puedes conseguir 10 + 10 + 0.020 = 7100000 ???
Eso, ni Houdini...
Has pensado en alguna pista rota/corroida, entre dichos resistores?
Ares332
Aveces suelo hacer magia, pero nunca tanta 🤣🤣, listo ya quedó la MacBook, ya enciende, solo me falta probar si funciona el SSD ya que recuerdo no lo detecta a, pero mañana te confirmo para ver si me puedes ayudar, dejo una foto de el problema, solo le bajó la calidad a las fotos porque no me deja subirlas, muchas gracias amigo por la ayuda
Ares332
amigo, regreso este equipo se calienta al cargar, el cargador llega hasta 50grados centigrados, y en consumo llega hasta 4.5A, aparte cuando se utiliza con la bateria, se descarga muy rapido. te pongo los links de los videos de la camara termica.
con cargador
Sin cargador
Si la bateria es vieja, o china, no puedes esperar que aguante mucho.
Ademas, cuando se usa la grafica dedicada, el consumo sube.
Al menos revisa cuantos ciclos lleva la bateria.
"el cargador llega hasta 50grados centigrados"
No me parece una temperatura muy elevada.
Es normal que caliente si hay gran consumo; 85W Apple original?
Desactivar GPU disminuye el consumo y alarga la vida de la bateria.
