820-3787-A mid 2015 DG power cycle
eclipsevl
I've got a 820-3787-A board which is stuck in power cycle. PP3V3_S5 is fine. Got orange led on the magsafe plug.
With multimeter I could see that PP1V5_S0, PPVCC_S0_CPU, PP1V5R1V35_GPU_REG_R, P1V05_S0GPU_REG_R, PP1V05_S0_REG_R, PP1V35_S3, PP5V_S4 are trying to start up, there is a voltage for a fraction of a second.
Couple of times after powering the board up, I saw PP1V5R1V35_GPU_REG_R at 1.5V and fans started to spin. It happened twice.
Another two suspicious things:
1. There was a blown ceramic cap at PP1V5R1V35_GPU_REG_R line, however without making short circuit. After removal I found that pad connected to PP1V5R1V35_GPU_REG_R was not making contact - pcb pad was ripped off. Cap itself was shorted. Didn't look like it was mechanical damage.
2. SPI flash was soldered - there is residue of a flux. Not sure if it is relevant to problem with startup sequence.
Resistance at PPVCC_S0_CPU is ~35 Ohm, P1V05_S0GPU_REG_R ~200Ohm, PP1V5R1V35_GPU_REG_R ~150Ohm. Could not find any visually bad component/short circuit.
Need some help with further debug.
Be sure to correctly rebuild the broken trace; where you've found the shorted cap.
Test if machine turns on in SMC bypass mode.
Check all SPI Bus Termination resistors and their traces.
PLT_RESET_L pulsing too?
Just in case, flash known good BIOS, clean ME.
eclipsevl
Thank you! :)
There were no broken traces, looks like cap was connected only to via.
There is 3.3k resistor at CS, no external resistors on other lines.
Yes, there is a pulse.
Ok, this is new to me. I will figure out how to program SPI flash, but have no idea where to get bios image. Hope it is possible to google it somewhere.
eclipsevl
Ok, got weird results in SMC bypass.
1. First attempt it started right away, fans spinning 100%
2. Second attempt - It started at like after ~4-5 cycles (power up cycles).
PPVCC_S0_CPU = 1.8
PP1V5R1V35_GPU_REG_R = 1.5
P1V05_S0GPU_REG_R = 1.05
PP1V05_S0_REG_R = 1.05
PP1V35_S3,
PP5V_S4 = 5
PPVOUT_S0_LCDBKLT = 0 (should it be high in SMC bypass?)
After that - it always need several cycles to start up. Feels like there is a bad cap somewhere.
You've said ripped off capacitor pad.
Not sure if was in the middle of the via; was the reason I mentioned trace continuity checking.
Starting in SMC bypass suppose a problem with a SMC sensor (pages 44-46); check AVREF_SMC first.
When started, check for USB activity; don't waste time checking backlight yet.
eclipsevl
AVREF_SMC = 3.3V
Did not check USB activity yet; checked activity on SPI CS line - always high.
New observation: even without SMC bypass board eventually starts up for ~5 seconds (CPU, GPU voltages), shuts down. Then cycle repeats.
The only difference with SMC bypass: after startup it does not shuts down.
Not sure if it says something.
Thank you so much for the bios!
