820-3787-a
Bunuffin
Hello
I have orange light on the charger, get 20v at the u7100 DCIN, i have 1 volt on ppbus_g3h even without the u7100 on the board, don't see any short on the coils
I replaced the u7100 since it was blown.
Bunuffin
Ppbus has no continuity
17/18=3ohm
19/20=4.8ohm
27/28=4.9kohm
Ps: these measures were made without the u7100 being on the board
"27/28=4.9kohm"
Fix the problem; check R7121/22 and their traces.
"Ppbus has no continuity"
I didn't ask that...
Bunuffin
"What is the diode mode to ground reading on PPBUS_G3H?"
I get 0L reading on my multimeter, sorry I miss read...
I have tested the rails and I don't see disconnects or high ohm.
I see 778ohm across R7121 and 3.9khom across R7122.
I'm sorry but I'm a noob so please be patient with me
Resistors value marked on the schematic.
Seems that both are bad in this case.
"I get 0L reading on my multimeter"
Learn how to properly use the multimeter in diode mode:
Bunuffin
I'm gonna get me the schematic, board viewer it's not enough, will scavenge resistors from the donor, then I will report.
This is my reading, reverse is the same, it reads something for a second then I get this...
These are correct values; doesn't seem to have any problem with PPBUS_G3H rail.
Just fix R7121/22 problem...
