820-3787 - Chime loop wich battery
This board works fully (in limp mode / 800MHz) when the battery is disconnected. When the battery is connected it chimes repeatedly, so at the end of the chime, it chimes again. A different battery produces the same result. Replaced ISL6259, didn't help. Any thoughts? Could this be GPU related?
Assuming you mean safe mode (holding shift), same behaviour. Both current sense circuits measured fine when I replaced the ISL.
NO, I exactly mean SMC bypass mode; explained many times on the forum how to do it.
Google can help you, in case forum search not...
It won't let me do that, it starts instantly when I press the power button. Only thing I have left to try is corrupted BIOS maybe? Any other ideas?
Ok, I started testing for the suggestions above, but noticed the heatsink got hot real quick. Turns out phase 1 of the GPU is pulling ±35A from the start. GPU problem? I'm confused as to why that VR would even start at this point during POST/boot.
GPU should have the same behaviour for start sequence, w/ or w/o battery.
Check the mentioned sensors level and post PPBUS_G3H voltage with both battery and charger connected.
Is the battery charging?
With 1.7-2.6A through R7150, CHGR_BMON should be higher than 0.05V.
ISL6259 gain for BMON is 36X.
2.6 x 0.005 x 36 = 0.468V which should get there.
Your problem could be ISL6259, or SMC...
So, I've been struggling with this one over the last few days.
* Replaced ISL > No change
* Replaced SMC > Didn't work (possibly faulty SMC)
* Replaced SMC with 3662 version and clean BIOS > Same behaviour (this one is just for testing, as I don't have any more 3787 donors)
I'm guessing some line gets overloaded, but not sure how to check this...
