820-4924-A dead
Soji
No light on the MagSafe. But the mb is showing low battery logo on the screen after pressing the power botton.
I discovered that f7005 is out, I replace it and it blew again after Pluged in charger.
I removed u7100 and replace another fuse.
the orange light came on, I installed another u7100 from a donor board, the orange light came on and q7130 started getting very hot.
I removed u7100, Q7130 stopped getting hot.
pls what can I do next. Thanks
Soji
There is a short on r7150 (0.001)
Replaced q7130, diode mode to ground on r7150 now is (0.117).
but ppbus is still 1.1v.
U7100 is getting very hot
Q7130 is getting warm.
Soji
Ok btw resistors is 516
But ol on switching probe. , note-this reading is without u7100
After I Installed another u7100 the MagSafe is flashing green light.
ppdcin voltage goes up and down between 13v and 2v
Ppbus is 1.1v.
PPDCIN_G3H usually fluctuates when leakage is detected.
What happens with lab PSU, or fake charger?
Post U7100 basic voltages; pins 1, 2, 3, 9, 12, 13, 14, 15, 17, 19, 20, 27.
Soji
2-0.031
3-0.00
9-0.00
12-0.00
13-0.00
14-0.09
15-0.00
17-0.161
19-0.00
20-0.00
27-2.431
I expected these voltages with lab PSU.
Why would you want to check something which you know doesn't exist with original charger???
Soji
Psu
1- 0.00
2-17.66
3-4.36
9-0.90
12-3.42
13-3.39
14-3.39
15-0.00
17-12.61
19-5.53
20-5.54
27-18.03
Soji
R7121 10.1k
R7122 10.4K
With Lab psu I have ppbus and fanspin.
The traces are good.
0.028 is close to expected value; should be 20 ohm.
However, R7120/21 can't have 10K each one; 10 ohm is other thing.
Please, post accurate information.
Change Q7180 and test again with original charger.
