820-4924 No Fan Spin after it gets hot
No-Clean
Board had some corrosion around R5117 near the SMC, fixed that but the original problem of the computer restarting still there, I have boiled it down to the fan not working.
Already replaced SMC, clean BIOS, Q6060
R6060/61/65 all ok
SMC bypass also no fan spin
Shorting SMC_FAN_0_CTL to ground also no fan spin
New fan also no fan spin
At fan connector I have PP5V_S0 5V, FAN_RT_TACH 3.3V
Please advice.
Compare diode mode to ground readings on Q6060 pins with good board.
Also compare voltages; do that in SMC bypass, when fan should spin.
