820-4924 - No green light Help
ipcrepair2
this unit came in no note, no liquid damage at all
please help :(
all the lines below checked continuity to ground and none found
]ppbus_g3h 12.26
pp3v42_g3h 3.413v
d7005 pin 1 20.37 pin 2 12.26 pin 3 20.18v
PPVIN _S5_HS_COMPUTING_ISN 12.26
PP18V5_DCIN 12.36
PP3V42_G3H 3.42
PP5V_S5 0v
PP3V3_S5 0v
"d7005 pin 1 20.37 pin 2 12.26 pin 3 20.18v
PP18V5_DCIN 12.36"
Are you sure?
BTW, 20V into MacBook Air, why?
15V is not good enough?
Check the voltage mark on the original charger.
Post SMC_RESET_L level.
ipcrepair2
PP18V5_DCIN 20.43
SMC_RESET_L 3.38
oem charger 85w
820-4924 this is macbook pro :/
STOP using incorrect charger.
It can trigger VD0R sensor and SMC doesn't like that.
Don't you have all Apple series chargers in the shop?
Check diode mode and voltage on the SCL/SDA lines of the battery bus; w/ and w/o battery connected.
Do you get 12MHz at Y5110?
Post its DC voltages, if don't have an o-scope at hand.
