820-4924 no SSD
Kyle93
Arrived intermittently not booting from internal SSD. Liquid damage all around U3740 area.
Replaced everything in the area but now cant boot from internal SSD at all now.
U3740 pin 6 3.2V pin 7 1.358V pin 8 0V pin 3 3.2V
U3740 has been replaced twice now. Is it possible both U3740 are bad? Should something else be checked?
Pin 7 should be steady 0V.
Check R3744/45 and all traces around.
Be sure to have good circuits to J3700.
Also check U3710/11.
Kyle93
R3744 is no stuff on this board and on a working board? R3745 is good
U3710/11 3.3V
Pin 4 3.3v
R3744/45 must be present at same time on the board.
The other option is soldered R3743 and R3744/45 not used any.
Alos, as MOMOH mentioned above, check if SSD_RESET_CONN_L is high.
Do you have R3744/45 on the board, or just R3743?
Check all the C371x caps and traces around J3700.
Also clean the connector pins.
Kyle93
Just R3743
Replaced all of the C371x caps just to rule out but no change.
Board has been through ultrasonic but no change.
Ultrasonic bath can clean corroded areas.
But also can break some corroded traces; and will nor rebulid that!
You must be very careful, as an ultrasonic cleaner without sweep option can make more damages on the board.
You must re-check all traces continuity and small resistors.
"Just R3743
R3745 is good"
What do you think?
