Clean board, sometimes when the battery is disconnected and connected again trackpad and keyboard works fine for a few hours or days, but it always comes back with no trackpad and keyboard.
Thanks, when it happens even at login screen no trackpad and keyboard and no boot menu option.
So if the trackpad cable goes bad keyboard doesn't work?
Recently you helped me fix an Air with similar issues but that mode the keyboard and trackpad connect via the same cable, on this MBP they connect via different cables.
MBP came in with the problem, I did some measurements, put the board back in and it works again, this has now happened a few times in the course of 3 months.
