A-820-00840 - Stuck at 5V 0.05
Start checking diode mode to ground at PPBUS_G3H; be sure F7000 is good.
Post U7000 basic voltages; P_IN, AUX_DET, SMC_RST_IN. VDDA/P, EN_VR1; SMC_RST*, AUX_OK, A/BMON.
nameless
thank for your reply )
F7000 - is good
PPBUS_G3H - 0.45
U7000 :
P_IN - 5V
AUX_DET - 1.28V
SMC_RST_IN - 0V
VDDA/P - 0.38V
EN_VR1 - 0.29V
SMC_RST - 0.1V
AUX_OK - 0V
A/BMON - 0.28 on both
nameless
Great I've got back the 20V after replacing U7000.
So now I have steady 20V, fan spins ones and amps go to 0.6 and back to 0.05A
So basically looping as before I short-circuited the U7000
nameless
it goes like this
when plugged, voltage goes to 3.6V
when fan starts to spin, goes up 13V
after back to 3.7V, then 4V, then 0V and back to 13V
and fan does spin any more.
Tested on F7000 pin2
I'm not sure what you've meant.
Can you check ALL big coils for voltage pulse (at least), when fan spins???
nameless
oh okok sorry for confused post
so fan spins only once then stops and doesn't spin anymore.
on coils I get
L7210, L7220 - pulsating 0.94V to 0V
L7370 - pulsating 1.05V to 0V
L8060, L7900 - pulsating 1V to 0V
L7960 - pulsating 0.9V to 0V
L8030 - pulsating 1.2V to 0V
L7030 - pulsating 13V to 0V
L7730 - pulsating 1.05V to 0.65V
L7410,20,30 - 0V
L7960 - pulsating 3.3V to 0V
L8410 - 0V
L7670 - pulsating 5.1V to 0V
nameless
still the same behaviour.
Tried on both ports : it goes till 0.60-0.65A and back to 0.05A and steady 20V
fan spins only once and rapidly stops
Probably bad CPU.
Power on sequence seems to completes, if you get VCORE pulse.
So there must be communication problem.
PLT_RST_L pulsing too?
Just in case, check for short and voltage pulse on all outputs from page 64.
Also check L7930.
nameless
yep also pulsating
PLT_RST_L - 1.29V
L7930 - 1.79V
on page 64 I have 4x mono speaker amplifier, is that it ?)
I'm using 820-00840 (ZEON) Schematic diagram
nameless
sorry for late reply was very busy
hmm weird on first attempt to measure on U8200 I had basically the same OUT 1.79
but on further attempts i'm getting 0V on IN and OUT
U8200
U8205
U8210
U8220
VIN1 - 0V
VOUT - 0V
