A1278 820-3115-B no backlight
hgoncalves
I have an A1278 820-3115-B with no backlight. It works, gives image on external monitor, and with a flashlight on the back, it shows image.
I don't understand this readings:
On F9700 I get 0V on the pad 1 and it seams that PPBUS_3GH is shorted
PPBUS_3GH = 0V 0 ohm and 0V on diode mode.
But everything seams to be working besides the backlight.
Already removed F9700 with same readings.
Can you help?
I hope you removed charger and battery when tested diode mode at F9700.
In fact, you should allow 15-20s before making any ohm, or diode mode reading on PPBUS_G3H.
Post D9701 voltages, if exist.
Be sure R0910 is good first.
hgoncalves
D9701 has 0V on both sides, and R0910 seams to be ok 0hm.
PPBUS_SW_LCDBKLT_PWR_SW seams to be shorted (0V in diode mode). shall i replace U9701?
hgoncalves
It's on PPBUS_SW_BKL
Already replaced C9712, C9713 and R0910 but still shorted
