A1278 820-3115-B safe mode
hgoncalves
I have an A1278 820-3115-B that only boots in safe mode, and I don´t know where to start.
After login the screen starts to freeze, and shows some strage things (seams like GPU problem), and in safe mode it logins in a normal way and works well.
With an external disk and other OS it has the same behavier
Can you help?
Install Windows and check if crashes when install graphics driver.
You can also run ASD OS version for detailed information.
hgoncalves
It installed windows 10, but it has a strange behavior. It seams that it has some kind of GPU problem, because the image freezes, and gets stuck for a while continually.
