A1369 have 3 beeps how to diagnose?
Tillie14
Hi I am new to this forum. I am from the Netherlands, and a very newbee in repairing on motherboard level.
This is my problem I have three beeps on startup and no screen.
I have already reflow the memory modules, without success
Is there a way to find out which memory module is may be faulty or needs to be reballed before reballing all of them ?
Reballing is not a definitive solution.
You should change all RAM chips.
Be aware, the problem can be also caused by CPU, or its broken traces/solders.
piernov
Moderator
In general on A1369 it's not the RAM itself. 2010 is probably MCP, 2011 is more likely CPU or bad pad/trace. No definitive solution to this.
Tillie14
I found some liquid damage on the u6100, also on pin8 of the u3690 and some green corrosion on testpoint tp[1] DP_A_BIAS could this be the problem?
Tillie14
I have heaten the CPU according your advice, but no luck. It is still beeping 3 times.
Is there a way to measure which RAM is defective?.
Or do I have to measure something else before start replacing the RAM modules.
No way to detect a failing RAM chip.
You can change them all, but be aware about CPU issue (maybe not RAM).
