A1398 820-00138-A no boot
Really strange.
If BKLT_SD is high, you should NOT have voltage at all at D7701.
Did you measure correctly?
hgoncalves
Well, i think i wasn't. My boardview on this board isen't good for sure. The D7701 isn't there. I was mesuaring on D7720. Do you have a good bordview?
Real boardview not available.
820-00163 has some differencies.
In your board, D7701 is placed between coil and filter caps.
D7720 is for keyboard backlight.
45V is a bit higher than normal backlight voltage.
I think 39V is correct level.
This means you have a problem with video cable, or broken LED strip inside LCD panel.
You may also have bad contacts inside J8300.
The Apple logo lights on the top cover?
If not,
"you have a problem with video cable, or broken LED strip inside LCD panel.
You may also have bad contacts inside J8300."
Did you check backlight voltage on the working moment?
Note it, as it will help you in the future diagnostics.
hgoncalves
Yes I note it and it is 45.7V. I Don't know if this is the right voltage for this model, but in this particularly mac (is the only one that I have here), that is the backlight voltage, on a working state. On future one, I'll compare it.
Thanks.
hgoncalves
After all, It doesn't work again. Something very strange is happening:
Once again, after i replaced the J8300 the backlight works for a day or two, but than it stops working.I gues that is someting related with the temperature applied (just guessing).
Any idea of what mite be causing this behaver?
What is backlight voltage now.
If higher than normal, there is a problem with the connection with LEDs strip.
If voltage is correct, then you have a problem with the image.
If lower, or missing voltage, then be sure to get image first.
