A1398 820-3071-A with no image
hgoncalves
Hi, after remove the L8930 the short seems to be gone (3 M ohm on PPBUS_G3H ), but the coil seems to be ok (at least it has continuity).
I have another board for parts, but it doesn't have the L8930/60 coils.
Can you tell me on witch boards can i get an 0.2UH-20%-24A-0.003OHM coil,or if i can use other from that board with a different value?
The coils are good, more than sure.
Replace high-side MOSFETs from GPU power supply (Q8930).
After that, post resistance to ground at L8930/60 and PPBUS_G3H; before applying power.
You can inject 1V there and check if GPU gets hot.
Remove heatsink first.
Let amp to max on PSU.
You may need 20A PSU for test...
hgoncalves
I don't have a 20 A PSU, but even with one of 5A, it only consumes 0.555 A. and don't gets hot. On thermal cam, i can't see anything hot
hgoncalves
With 1.2V it only consumes 0.655Amp, and still nothing hot. What do you mean with "Check directly on GPU die"?
hgoncalves
Something change, and i can't figure out why;
now i have
L8930
PIN 1 = 23 k ohm
PIN 2 = 21.80 ohm
L8960
PIN 1 = 0.40 ohm
PIN 2 = 21.80 ohm
Both coils out
hgoncalves
hi,
After resolderind both coils, all shorted again. All mesures in both coils arround 0.50 ohm.
L8960 seams to be a little damaged. Where can a take a similar coil on this board?
These coils have no pin connected to ground!
How then a coil can pulls down to ground???
Lift the coils again and check resistance to ground on each pad.
BTW, did you apply power to the board???
hgoncalves
After replacing Q8961 i get those:
Both coils out:
L8930
PIN 1 = 26 k ohm
PIN 2 = 27.00 ohm
L8960
PIN 1 = 25.90.K ohm
PIN 2 = 27.20 ohm
Aren't pads 2 to low?
hgoncalves
After resoldering both coils, everything is shorted again (40ohm on every pad). After lifting both coils, everything goes to normal values.
I can only assume that the coils have some kind of problem. Am I right?
If so, where can i take similar coils on this board (the board that i have for parts, doesn't have those coils anymore)
hgoncalves
I have 26.60 ohm on every pad, and no short on PPBUS_G3H (15 k ohm) and 0.450V on diode mode.
Can i try to power it on?
