A1466 2015 MacBook Air not charging or turning on, reverse charger light behavior after liquid damage
vinaypundith
The laptop had drinking alcohol spilled on it. Cleaned the board with (isopropyl) alcohol, replaced the keyboard, a week later it's dead with no power.
When you plug in a charger, the LED on the charger lights up green. If I disconnect the battery from the motherboard and then plug the charger in, the charger lights orange. (Reverse of expected light behavior???)
PP3V42_G3H rail as tested at keyboard connector (J4800) is at 3.40V.
I don't see any corrosion at either end of the ribbon cable going to the DC IN board. Replacing the board had no effect.
What should I test first? Thanks!
