A1466 820-00165-A it doesn't turn on
"R8050 is 0.042"
What this means?
It is 0 ohm resistor...
"i Have a short on C7462"
Are you really sure?
You've said to have correct L7430 voltage.
"ALL_SYS_PWRGD should be high then.
Remove Q8150 and check it again."
Paky46
"R8050 is 0.042"
What this means?
after i removed q8150 the voltage went back to 3.3 and the fan started
Then you should have ALL_SYS_PWRGD present even with Q8150 soldered on the MLB.
Put it back and check again its voltages.
In this case, CPU core voltage should be present; check L7310/20 voltage.
Also check PLT_RESET_L level.
Paky46
I mounted the mac and now it turns on and works I don't have the password to try everything but I'm waiting The only thing I found is that the magsafe light does not turn on
