A1466 820-32-09-A no power
hgoncalves
I have an A1466 820-3209-A that has green light, but no fan spin.
It takes 0.400 A no PSU and them drops to around 0.250A.
I think that I have a short on PPCPUVCCIO_S0_REG because on L7630 I get:
Diode mode =0.0216V and 11.90 ohm off resistance to ground.
Is this shorted or low resistance circuit?
Can you help?
Just replaced U7600 but still the same. No fan spin, and the same values on pins. 3. 13 and 14 of U7600
Hi, sorry. I was not sure and decided to replace it.
R/C7981 are good, and on PIN 3 of U7780 I also get 0.5V
R7981 has 20K ohm, and 3.3V on both pins, and C7981 isen't shorted (diode mode has normal values). I'll replace both just for sure.
