A1502 820-3476-A intermittent backlight
Hi guys
Got an A1502 here that has a backlight issue. No sign of any liquid damage on the board, all seems clean.
The screen has a display, but the backlight is intermittent. By that I mean that sometimes it will boot normally, screen will light, all is good.
Sometimes however it won't light up, it has a display but no backlight.
If I close the lid, the screen turns off as usual, opening it again results in no backlight most of the time.
Is there any point I should be starting to look at first?
PPV_OUT_S0_LCDBKLT (measured at Pin1 of LVDS connector) is 38v when functioning but reads at 11.5v when backlight is off.
I dimly recall something about SMC_LID and the hall sensor - is that a common area I should look at?
Many thanks
Can't delete my post so I'll update - there IS liquid damage, didn't see the tiny spot of corrosion right underneath the backlight controller, will sort that and post back if there's still a problem!
Cheers!
If cleaning board doesn't help, be sure to use original charger.
MagSafe 1 to 2 adapter can cause that...
Cleaning the board (removed the Q7700 IC and cleaned / resoldered), and the backlight driver, all seems well now with an instant backlight response rather than the delayed response I was getting before.
However, wasn't aware of the Magsafe 1->2 adapter issue - will lodge that in the memory bank!!
Many thanks
