A1534 820-00045-A no power
hgoncalves
I have an A1534 820-00045-A that has no power.
It takes 5.16V from ampmeter and 0A.
I have 5.16V on F4700 and 0V on 3V3R3V0_AON.
Diode Readings:
3V3R3V0_AON = 0.331
E85_CC1 = 0.555
E85_CC2 = 0.555
I supose that it can be related with U4700. Am I right?
Can you help?
hgoncalves
R7101 = 0 ohm
R7104 = 4.6 ohm
C7100/01 seams to be ok, but I've removed both. However, I still have the same behavier.
CHGR_LDO_P5V0 (on R7104) = -0.141V
Shall I replace R7101/04 ?
I've got confused between voltage and diode mode at VDDA/P pins, sorry.
However, you should change U7100 again.
hgoncalves
I've replaced U7100 again (twice), but same thing. However I get some strange readings (I think):
I've used 2 multimeters and in CHGR_LDO_VDDA I get negative voltages (-0.221V), and on CHGR_LDO_P5V0 I get -0.080V. Does this make any sense to you?
If U7100 is good for sure and properly soldered, then must have a problem with surrounding components.
Check diode mode to ground at L7095 and F7140.
