A1534 820-00244 no power
hgoncalves
I have an A1534 820-00244 with no power.
I have 20V on ampmeter, but 0A.
No big coil seams to be shorted.
PP3V3_G3H = 3.289V
PP5V_S5 = 5V
PP5V_S0 = 0V
PP3V3R3V0_AON = 3.298V
PP3V3_S5 = 0V and 0.388 on diode reading.
PP3V3_SUS = 0V and 0.398 on diode reading
Can you help?
hgoncalves
PPBUS_G3H has 8.69V with, and without battery connected.
SMC bypass has the same result (no power on)
Any fault history available?
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
hgoncalves
Client said it stoped working over night.
PM_PWRBTN_L has 0V and no drop pulse when triggering SMC_ONOFF_L.
hgoncalves
Hi.
R1570 has 0.994 ohm (prety close to 1k I think), and PM_PWRBTN_L has 2k resistance to ground.
Shall I replace R1570?
"R1570 has 0.994 ohm"
You've meant Kohm, I suppose...
"PM_PWRBTN_L has 2k resistance to ground"
Compare with good board; use diode mode instead.
