A1534 820-00687-A no power on
hgoncalves
I have an A1534 820-00687-A that doesn't power on. On the ampmeter it puls 20.5V, but 0A. Already tried a new flex cable, but no success.
I'm using one boardview and schematics of a 244 (not sure if this is OK, but don't have a 687)
PPBUS_G3H = 8.68V
PPBUS_S5_HS_COMPUTING_ISNS = 8.68V
PPVBUS_LIO = 20.54V
PP3V3R3V0_AON = 3.3V
PPVRTC_G3H = 3.0V
PP5V_G3H = 5.1V
PP5V_S0 = 5.1V
PP3V3_S5 = 3.3V
PP3V3_S0 = 0V
PP3V3_SUS = 0V
On PP3V3_S4, mesuaring on R7801 I only get 1.6V; On L4802, I only get 1.6V, and on pin 12 of U1900 I get 0V.
Can you help?
hgoncalves
Sorry, you're right.
PP5V_S0 = 0V
PP5V_S5 = 5.1V
PP5V_S4 = 5.1V
The other mesuarements are correct.
To enter S4 state, board must pass through SUS first.
Still unclear ho do you get S4 voltage, but no 3V3_SUS.
PM_SLP_SUS_L missing for sure?
hgoncalves
Unless my schematics is wrong (I'm using a 244 board schematics), I think that I'm reading it corectly.
I'm measuring 3V3_SUS on C6100, and C6101, and I get 0V on both.
PM_SLP_SUS_L on R1554 has 0V also.
PP5V_S4 on R7100 has 5.1V
PP3V3_S4 on L4802 has 1.7V
From schematic looks this board has different behavior for SUS state.
If you get 5V_S4, then 3V3_S4 must be present too; same enable signal is used for both rails.
Check diode mode to ground at 3V3_S4.
If good, then change U8200.
Be sure to get 3V at its ON pin.
hgoncalves
Diode reading on 3V3_S4 is ok (0.491).
I've replaced U8200 but no sucess. However, now on 3V3_S4 I have 2.83V.
Voltages on U8200: I have PP3V3_S5 (3.3V), but on PM_SLP_S5_L (pin 6) I have 0.055V. Can it be U5000 or a bad U8200?
hgoncalves
I don't have continuity from U8200 to U7650, but i have from U8200 to R8305 (pin 1), and I have from U7650 to R8305 (Pin 2).
On R8305 I read 9.96 kohm, but my schematic doesn't have R8305 (and I don't have other board to compare), and so I'm not sure if the value is the correct one. Do you think that it can be it?
hgoncalves
Hi, yes, I'm using 00244 schematic and boardview.
I've checked continuity of PM_SLP_S5_L from U8200 to U7650, but it doesn't have continuity.
The schematic doesn't have it, but the boardview shows it (R8305).
hgoncalves
After replacing (twice) U8200, because I broked it, now I don't have PP5V_S4 (0V), neither PM_SLP_S5_L (0V), and only have 0.650V on 3V3_S4.
I have PP3V3_S5 (3.3V), and PP5V_S5 (5.0V)
PP5VS4_EN pin 4 of U7650 has 0.054V
3V3_SUS = 0.003V
Possiblly, the heat damage something else?
Did you get PM_SLP_S5_L present at U7650 for sure before?
I suppose PCH problem; possibly affected by the heat now.
hgoncalves
I never had PM_SLP_S5_L on U7650. I had 5.1V on PP5V_S4, but I didn't measured it on U7650; I've used R7100 to measured PP5V_S4 , and I'm sure that there I had 5.1V.
Shall I try to replace U7650?
hgoncalves
I understood your point, but I'm not sure if I had it there before, because I didn't cheked. I suppose I had it.
Can't it be U5000? R1553 should be 100k ohm (i think) but I'm reading a lot of oscilating values on it. Do you think that this can be related?
PCH is the one in charge to release PM_SLP_Sx_L signals.
Of course, it requires some other previous signals; like RTC and S5 power.
