A1706 820-00239-A No LED External Only / No SSD
Cire3
No liquid damage found. No power a the nand. Boots to external screen only, then flashes folder.
U8203 Gets really hot.
PP3V3_S5 Pin 1 - 3.36V
PP3V3_S5 Pin 4 - 3.37
PP3V3_S4 Pin 6 - 0.19V
Best method to isolate PP3V3_S4 ?
Cire3
That was helpful, found short in cap C4205. Didn't take much at all. (Had to order)
U8203 cooled down
PP3V3_S4 Pin 6 3.36V now
However now, no display? Gonna poke around, but good progress !
Cire3
Must have goofed something up. I do have video.
I have external video Via USB C. Still a flashing folder. Unit is running outside of chassis.
Sorry, also a first responder. So time on this has been sporadic at best this week.
So missing internal video?
In such case, check diode mode to ground at pins 1 & 3 of J8500.
Is the lifeboat connector (J9600) closed?
Cire3
Yes, checked J9600 is closed. Appears clean and connected.
unsure of internal video, board is out. Flashing folder on boot. Booted to disk utility, unable to see SSD.
J8500
Pin 1 : 0.314
pin 3 : 0.315
This unit they are really looking for the data.
Cire3
Trying to trace SSD Nand power. Schematic shows U5910. I see soldered pads, but missing ?
Doesn't look ripped off?
Cire3
Trying to track down the data sheet for 58879D CSD55879Q3D = U7600
Not finding a whole lot. Ordered this as the closest I could find from Digi key
CSD87334Q3DT​
