rkrishnan
Hello folks,
I recently bought a water damaged A1706 touch bar that doesn't have any chime (and obviously no display or fan). When connected to a USB-C monitor, the monitor turns on but no display (indicating its drawing some power). Here are the measurements I took - do you have suggestions on where I should check next? There was a considerable amount of water residue / corrosion near the battery area.
CPU gets luke warm (not really hot) after leaving it for 5 minutes.
820-00239-A
PPBUS_G3H - C6483 - 12.89V
PP5VS4 - L7600 - 5.06v
ALL_SYS_PWRGD - R7103 - 3.19v
CPU_VCCST_PWRGD- probe point - 0.98v
PM_PCH_SYS_PWROK - probe point - 3.29v
SMC_DELAYED_PWRGD - R5191 - 3.38v
PPBUS_HS_CPU - C7903 - 12.03v
PPVCC_S0_CPU - 0V (resistance to ground 17 ohm, which I assume is normal)
PP5V_S0_VCORE1 - Pin 3 U7210 - 5.07v
PP5V_S5 - probe point - 5.06v
I tried reading the schematic but am lost at how PPVCC_S0_CPU is produced. I guess it could be U7210, but was hoping someone has seen something like this before.
Thank you! I really hope this isn't a dead CPU, as I was hoping to resurrect this as my personal laptop.
820-00239-A
